Still going through maillogs, the following is another warning that seems a bit odd:
Jun  4 12:25:11 server postfix/tlsmgr[19672]: warning: request to update table btree:/var/spool/postfix/smtpd_tls_session_cache in non-postfix directory /var/spool/postfix
Jun  4 12:25:11 server postfix/tlsmgr[19672]: warning: redirecting the request to postfix-owned data_directory /var/lib/postfix
Jun  4 12:25:11 server postfix/tlsmgr[19672]: warning: request to update table btree:/var/spool/postfix/smtp_tls_session_cache in non-postfix directory /var/spool/postfix
It's a warning so not sure if we should be too concerned, but has anyone seen this one before and know how to fix?
						postfix tlsmgr smtpd_tls_session warning
Re: postfix tlsmgr smtpd_tls_session warning
Shawn is there an available workaround ?
Yep.
/etc/postfix/main.cf
Change the following
to...
Reload postfix
smtp_tls_session_cache_database = btree:/var/spool/postfix/smtp_tls_session_cache
smtpd_tls_session_cache_database = btree:/var/spool/postfix/smtpd_tls_session_cache
smtp_tls_session_cache_database = btree:/var/lib/postfix/smtp_tls_session_cache
smtpd_tls_session_cache_database = btree:/var/lib/postfix/smtpd_tls_session_cache
sudo service postfix reload
