I really need some help on how to whitelist IP ranges. I have tried adding the subnet into the whitelist on the mailwatch website but it doesn't seem to work when you use the IP and subnet mask.
Can someone help me adding the range of IP's. I need to whitelist the mailchimp IP ranges below.
205.201.128.0/20
198.2.128.0/18
148.105.0.0/16
whitelist ip range
Re: whitelist ip range
I believe its (kind of) classful. (but not really)
Syntax: (Note trailing dot)
Class C: 192.168.10.
Class B: 192.168.
Class A 192.
Source
Class B: 192.168.
Class A 192.
Source
Thanks. I had a look but cant work out how to add those IP ranges in.
I think I need someone to dumb it down for me lol.
To calculate the IP ranges you could use the Subnet Calculator https://mxtoolbox.com/subnetcalculator.aspx
CIDR _________ | CIDR IP Range
198.2.128.0/18 = 198.2.128.0 - 198.2.191.255
The best option is to sit down and take some time to read about CIDR notations
https://en.wikipedia.org/wiki/Classless ... in_Routing
I have the CIDR ranges. I just need to know where to enter them so we can whitelist the IP ranges.
205.201.128.0/20
198.2.128.0/18
148.105.0.0/16
205.201.128.0/20
198.2.128.0/18
148.105.0.0/16
148.105.0.0/16 would be it in as 148.105.
Thes other to need to be put in as seperate /24's aka
205.201.128.
205.201.129.
etc
etc
205.201.128.
205.201.129.
etc
etc
