Can't add relay-country header to all messages...
iandarke
Post by iandarke » 22 May 2020 17:40
File: /etc/MailScanner/spam.assassin.prefs.conf
Content added to end:
ifplugin Mail::SpamAssassin::Plugin::RelayCountry
header          RELAYCOUNTRY_BAD X-Relay-Countries =~ /^(CN|RU|DE)/
describe        RELAYCOUNTRY_BAD Testing country relay plugin
score           RELAYCOUNTRY_BAD 0.1
add_header all Relay-Country _RELAYCOUNTRY_
endif # Mail::SpamAssassin::Plugin::RelayCountry
I restarted spamassassin and mailscanner, but I was expecting to see something like this in my mail headers:
X-Spam-Relay-Country: US CN RU
It doesn't seem like headers are being added, but I did spot this in a recent spam so I know the rule is working (although for some reason the description isn't??)
0.79	RDNS_NONE	Delivered to internal network by a host with no rDNS
0.10	RELAYCOUNTRY_BAD
0.00	SPF_HELO_NONE	SPF: HELO does not publish an SPF Record
I think my spamassassin configuration is correct and I'm *guessing* that something else in the spam processing chain is effecting the headers.
Sources:
https://cwiki.apache.org/confluence/dis ... ntryPlugin
viewtopic.php?t=1556
Re: Can't add relay-country header to all messages...
Post by pdwalker » 23 May 2020 05:56
iandarke wrote:
22 May 2020 17:40
Tools and Links, Update SpamAssassin Rule Descriptions.
That should fix that problem.
iandarke
Post by iandarke » 23 May 2020 19:40
Does anyone have any suggestions for where to look to get the extra header to be included? I think I'm creating it properly, but I'm guessing some later technology in the pipeline is removing it...?
Post by shawniverson » 23 May 2020 20:13
I think it is the way mailscanner calls spamassassin. I'll take a look.
