I downloaded the ISO and installed. I seem to be left with a vanilla operating system.
I'm not sure, but I think part of the problem may be that one of the RPM sources has moved:
Old URL: https://centos7.iuscommunity.org/ius-release.rpm
New URL: https://repo.ius.io/ius-release-el7.rpm
I've manually installed and it looks like the Build script is doing better now... here was the message BTW:
I tried to run the install script manually and I got:
[root@efa4 ~]# /usr/src/eFa/build.bash kstesting
2020.05.19-17:17:29 - =============  EFA4 BUILD SCRIPT STARTING  ============
2020.05.19-17:17:29 - Good you are root.
2020.05.19-17:17:29 - Good you are running CentOS 7
2020.05.19-17:17:29 - Checking network connectivity
2020.05.19-17:17:30 - OK - https://mirrors.efa-project.org is reachable
2020.05.19-17:17:30 - Adding eFa Testing Repo
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100   192  100   192    0     0    177      0  0:00:01  0:00:01 --:--:--   177
2020.05.19-17:17:32 - Installing IUS Repo
Loaded plugins: fastestmirror, langpacks
ius-release.rpm        |  137 B  00:00:00
Cannot open: https://centos7.iuscommunity.org/ius-release.rpm. Skipping.
Error: Nothing to do
2020.05.19-17:17:34 - ERROR: IUS installation failed
2020.05.19-17:17:34 - ^^^^^^^^^^ SCRIPT ABORTED ^^^^^^^^^^
						Fresh install from ISO ... IUS-RELEASE.RPM location needs to be updated
Re: Fresh install from ISO ... IUS-RELEASE.RPM location needs to be updated
Sure looks like it.  I'll update the scripts with the new url.
Install script worked like a champ once I had ran this.. Thanks!
I Noticed you used /usr/src/eFa/build.bash kstesting
thus using the eFa4-testing.repo and not the stable production mirror/rpm/eFa4/eFa4.repo
Depending on what you want with this eFa install, you can switch to the stable prod eFa repo quite easy afterwards.
viewtopic.php?t=3879
The IUS issue was reported some time ago viewtopic.php?t=4117
see the Build script (https://github.com/E-F-A/v4/blob/master ... build.bash), on line 180.
