Hi guys,
after tonight Cron emails are not delevering to the mail server.
[*]Jun 2 09:32:11 relay MailScanner[19847]: Virus and Content Scanning: Starting
Jun 2 09:32:11 relay MailScanner[19847]: Spam Checks: Starting
Jun 2 09:32:11 relay MSMilter[26412]: MailWatch: Whitelist refresh time reached
Jun 2 09:32:11 relay MSMilter[26412]: MailWatch: Starting up MailWatch SQL Whitelist
Jun 2 09:32:11 relay MSMilter[26412]: MailWatch: Read 38 whitelist entries
Jun 2 09:32:11 relay MSMilter[26412]: MailWatch: Blacklist refresh time reached
Jun 2 09:32:11 relay MSMilter[26412]: MailWatch: Starting up MailWatch SQL Blacklist
Jun 2 09:32:11 relay MSMilter[26412]: MailWatch: Read 0 blacklist entries
Jun 2 09:32:11 relay postfix/cleanup[26416]: 45GqdP1R9tzJfL4: milter-discard: END-OF-MESSAGE from sender35217.picsrv.net[145.255.135.217]: milter triggers DISCARD action; from=<pom-baisksdlsgd4rx2s@feedback.valk.nl> to=<erik@domain.com> proto=ESMTP helo=<sender35217.picsrv.net>
Jun 2 09:32:11 relay dccifd[7131]: continue not asking DCC 438 seconds after 5 failures
Jun 2 09:32:13 relay postfix/smtpd[24958]: disconnect from sender35217.picsrv.net[145.255.135.217] ehlo=2 starttls=1 mail=1 rcpt=1 data=1 quit=1 commands=7
Jun 2 09:32:14 relay MailScanner[19870]: New Batch: Found 2 messages waiting
Jun 2 09:32:14 relay MailScanner[19870]: New Batch: Scanning 1 messages, 154471 bytes
Jun 2 09:32:14 relay MailScanner[19870]: Virus and Content Scanning: Starting
Jun 2 09:32:14 relay MailScanner[19870]: HTML Img tag found in message 45GqdP1R9tzJfL4 from pom-baisksdlsgd4rx2s@feedback.valk.nl
Jun 2 09:32:14 relay MailScanner[19870]: Spam Checks: Starting
Jun 2 09:32:14 relay MailScanner[19870]: Expired 1 records from the SpamAssassin cache
Jun 2 09:32:14 relay MailScanner[19870]: MailWatch: Whitelist refresh time reached
Jun 2 09:32:14 relay MailScanner[19870]: MailWatch: Starting up MailWatch SQL Whitelist
Jun 2 09:32:14 relay MailScanner[19870]: MailWatch: Read 38 whitelist entries
Jun 2 09:32:14 relay MailScanner[19870]: MailWatch: Blacklist refresh time reached
Jun 2 09:32:14 relay MailScanner[19870]: MailWatch: Starting up MailWatch SQL Blacklist
Jun 2 09:32:14 relay MailScanner[19870]: MailWatch: Read 0 blacklist entries
Jun 2 09:32:14 relay dccifd[7131]: continue not asking DCC 435 seconds after 5 failures
Jun 2 09:32:16 relay postfix/scache[25764]: statistics: start interval Jun 2 09:28:56
Jun 2 09:32:16 relay postfix/scache[25764]: statistics: domain lookup hits=0 miss=4 success=0%
Jun 2 09:32:20 relay MailScanner[19847]: Requeue: 45GqdM66m6zJfL2 to 45Gqdc75BDzwk9T
Jun 2 09:32:21 relay postfix/qmqpd[26237]: connect from localhost[127.0.0.1]
Jun 2 09:32:21 relay postfix/qmqpd[26237]: 45Gqdc75p6zJfL2: client=localhost[127.0.0.1]
Jun 2 09:32:21 relay postfix/cleanup[26093]: 45Gqdc75p6zJfL2: message-id=<VE1PR08MB49441CEAB6ED67B4FC4B5375F21B0@VE1PR08MB4944.eurprd08.prod.outlook.com>
Jun 2 09:32:21 relay opendkim[6570]: 45Gqdc75p6zJfL2: no signing table match for 'Julien.NL@hotmail.com'
Jun 2 09:32:21 relay opendkim[6570]: 45Gqdc75p6zJfL2: DKIM verification successful
Jun 2 09:32:21 relay postfix/qmqpd[26237]: disconnect from localhost[127.0.0.1]
Jun 2 09:32:21 relay MailScanner[19847]: Uninfected: Delivered 1 messages
Jun 2 09:32:21 relay postfix/qmgr[7073]: 45Gqdc75p6zJfL2: from=<julien.nl@hotmail.com>, size=10800, nrcpt=1 (queue active)
Jun 2 09:32:21 relay MailScanner[19847]: Deleted 1 messages from processing-database
Jun 2 09:32:21 relay MailScanner[19847]: MailWatch: Logging message 45GqdM66m6zJfL2 to SQL
Jun 2 09:32:21 relay postfix/smtp[26239]: 45Gqdc75p6zJfL2: to=<julien@gislaved.org.nl>, relay=192.168.4.5[192.168.4.5]:25, delay=0.08, delays=0.05/0/0.01/0.01, dsn=4.3.1, status=deferred (host 192.168.4.5[192.168.4.5] said: 452 4.3.1 Insufficient system resources (SystemMemory) (in reply to end of DATA command))
Jun 2 09:32:24 relay MailScanner[19870]: Content Checks: Detected and have disarmed web bug tags in HTML message in 45GqdP1R9tzJfL4 from pom-baisksdlsgd4rx2s@feedback.valk.nl
Jun 2 09:32:24 relay MailScanner[19870]: Requeue: 45GqdP1R9tzJfL4 to 45Gqdh4jQJzwk9T
Jun 2 09:32:24 relay postfix/qmqpd[26237]: connect from localhost[127.0.0.1]
Jun 2 09:32:24 relay postfix/qmqpd[26237]: 45Gqdh4k2RzJfL4: client=localhost[127.0.0.1]
Jun 2 09:32:24 relay postfix/cleanup[26416]: 45Gqdh4k2RzJfL4: message-id=<25b2a6ce18543eb9df0f357299811d95@feedback.valk.nl>
Jun 2 09:32:24 relay opendkim[6570]: 45Gqdh4k2RzJfL4: no signing table match for 'mailing@mailing.valk.nl'
Jun 2 09:32:24 relay opendkim[6570]: 45Gqdh4k2RzJfL4: message has signatures from copernica.com, mailing.valk.nl
Jun 2 09:32:24 relay opendkim[6570]: 45Gqdh4k2RzJfL4: bad signature data
Jun 2 09:32:24 relay postfix/qmgr[7073]: 45Gqdh4k2RzJfL4: from=<pom-baisksdlsgd4rx2s@feedback.valk.nl>, size=160041, nrcpt=1 (queue active)
Jun 2 09:32:24 relay postfix/qmqpd[26237]: disconnect from localhost[127.0.0.1]
Jun 2 09:32:24 relay MailScanner[19870]: Uninfected: Delivered 1 messages
Jun 2 09:32:24 relay MailScanner[19870]: Deleted 1 messages from processing-database
Jun 2 09:32:24 relay MailScanner[19870]: MailWatch: Logging message 45GqdP1R9tzJfL4 to SQL
Jun 2 09:32:25 relay postfix/smtp[26239]: 45Gqdh4k2RzJfL4: to=<erik@domain.nl>, relay=84.243.215.76[84.243.215.76]:25, delay=0.43,
i had to reboot the box like 4 times to get the service restarted.
1 jun bug / emails are not released
Re: 1 jun bug / emails are not released
Having no issues whatsoever, I would say that the next messages in your log are pointing to the issue:
And check your available diskspace https://robot.lk/viewtopic.php?f=20&t=2972
Hi Henk,
i dont think its a HDD issue maybe more memory issue
my HDD is
my HDD is
[shell_user20@relay ~]$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/vg_00-lv_root 8.0G 1.8G 6.3G 22% /
devtmpfs 1.9G 0 1.9G 0% /dev
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 1.9G 25M 1.9G 2% /run
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/mapper/vg_00-lv_tmp 1014M 34M 981M 4% /tmp
/dev/sda1 477M 296M 156M 66% /boot
/dev/mapper/vg_00-lv_var 84G 5.7G 79G 7% /var
none 1.9G 320K 1.9G 1% /var/spool/MailScanner/incoming
tmpfs 379M 0 379M 0% /run/user/0
tmpfs 379M 0 379M 0% /run/user/1000Code: Select all
[shell_user20@relay ~]$ postconf -n
alias_database = hash:/etc/aliases
alias_maps = hash:/etc/aliases
command_directory = /usr/sbin
compatibility_level = 2
daemon_directory = /usr/libexec/postfix
data_directory = /var/lib/postfix
debug_peer_level = 2
debugger_command = PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin ddd $daemon_directory/$process_name $process_id & sleep 5
default_destination_recipient_limit = 1
disable_vrfy_command = yes
enable_long_queue_ids = yes
error_notice_recipient = root
header_checks = regexp:/etc/postfix/header_checks
html_directory = no
inet_interfaces = all
inet_protocols = ipv4, ipv6
local_recipient_maps =
mail_owner = postfix
mailbox_size_limit = 133169152
mailq_path = /usr/bin/mailq.postfix
manpage_directory = /usr/share/man
masquerade_domains = $mydomain
message_size_limit = 133169152
meta_directory = /etc/postfix
milter_default_action = tempfail
milter_protocol = 2
mydestination = $myhostname, localhost.$mydomain, localhost
mynetworks = 127.0.0.0/8 [::1]/128 192.168.4.5
myorigin = $mydomain
newaliases_path = /usr/bin/newaliases.postfix
non_smtpd_milters = inet:127.0.0.1:8891
qmqpd_authorized_clients = 127.0.0.1 [::1]
queue_directory = /var/spool/postfix
readme_directory = /usr/share/doc/postfix_eFa-3.3.0/README_FILES
recipient_canonical_maps = hash:/etc/postfix/recipient_canonical
sample_directory = /usr/share/doc/postfix_eFa-3.3.0/samples
sender_canonical_maps = hash:/etc/postfix/sender_canonical
sendmail_path = /usr/sbin/sendmail.postfix
setgid_group = postdrop
shlib_directory = /usr/lib64/postfix
smtp_tls_CAfile = /etc/postfix/ssl/smtpd.pem
smtp_tls_mandatory_protocols = !SSLv2,!SSLv3
smtp_tls_note_starttls_offer = yes
smtp_tls_protocols = !SSLv2,!SSLv3
smtp_tls_session_cache_database = btree:/var/lib/postfix/smtp_tls_session_cache
smtp_use_tls = yes
smtpd_client_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_rbl_client zen.spamhaus.org
smtpd_delay_reject = yes
smtpd_helo_required = yes
smtpd_helo_restrictions = check_helo_access hash:/etc/postfix/helo_access, reject_invalid_hostname
smtpd_milters = inet:127.0.0.1:8891 inet:127.0.0.1:33333
smtpd_recipient_restrictions = permit_mynetworks, reject_unauth_destination, reject_non_fqdn_recipient, reject_unknown_recipient_domain, check_recipient_access hash:/etc/postfix/recipient_access, check_policy_service inet:127.0.0.1:2501
smtpd_relay_restrictions = permit_sasl_authenticated, permit_mynetworks, reject_unauth_destination
smtpd_tls_CAfile = /etc/postfix/ssl/smtpd.pem
smtpd_tls_cert_file = /etc/postfix/ssl/smtpd.pem
smtpd_tls_ciphers = medium
smtpd_tls_key_file = /etc/postfix/ssl/smtpd.pem
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_database = btree:/var/lib/postfix/smtpd_tls_session_cache
smtpd_tls_session_cache_timeout = 3600s
smtpd_use_tls = yes
tls_medium_cipherlist = ECDSA+AESGCM:ECDH+AESGCMM:DH+AESGCM:EKCDSA+AES:ECDH+AES:DH+AES:ECDH+3DES:DH+3DES:RSA+AESGCM:RSA+AES:RSA+3DES:!aNULL:!MD5:!DSS
tls_preempt_cipherlist = yes
tls_random_source = dev:/dev/urandom
transport_maps = hash:/etc/postfix/transport
unknown_local_recipient_reject_code = 550
unverified_recipient_reject_code = 550
unverified_recipient_reject_reason = Address lookup failed
virtual_alias_maps = hash:/etc/postfix/virtual
- error.jpg (21.95 KiB) Viewed 5321 times
