Block filetype releaseable
ItemsGmbH
Post by ItemsGmbH »
Hi there
Following situation:
We receive tons of mails with .doc attachments containing a virus.
Now we configured our mailscanner to block all .doc files.
Is there a way to make the blocked file releaseable?
Now, if we need a file, we connect via ssh, copy the file & chown it. Then download it via ftp.
It would be great if we could just click at "release" ;)
I´m open for suggestions :-)
Re: Block filetype releaseable
This is very doable, you have to tweak MailScanner and MailWatch though...let me find my notes and post the steps...
# Do you want to store copies of the infected attachments and messages?
Quarantine Infections = yes
define('QUARANTINE_USE_SENDMAIL', false);
ItemsGmbH
Post by ItemsGmbH »
It works. Thanks a lot :D
Is it possible to release the whole mail with the attachment again instead of sending an extra mail with only the attachment?
ItemsGmbH
Post by ItemsGmbH »
*push*
I don't think MailWatch can release a blocked attachment using sendmail.
