Log history is only 4 days, how to increase?
maxkmv
Post by maxkmv »
Hi Community!
Not sure if this was asked before, but after one of the recent updates, for some reason I can only see the history of all messages going back 4 days. E.g. previously I could see a log of past 90 days or so..This is very useful in searches to see if the same IP address was sending me spam in the past, for example..
How do I enable to see it like before? I want to retain a history of 2-3 months (I don't need the actual emails, just the email headers).
maxkmv
Re: Log history is only 4 days, how to increase?
Post by maxkmv »
Found it myself.
In /var/www/html/mailscanner/conf.php
change RECORD_DAYS_TO_KEEP and AUDIT_DAYS_TO_KEEP to xxxx - where xxxx is number of days
Do you know how the value got changed?
maxkmv
Post by maxkmv »
It most definitely happened after one of the recent updates... My partition didn't have enough size to auto-update, so for about 6 months I didn't action any updates. Once I reduced my quarantine settings to fewer days, more disk space became available and I did several sequential updates (install-> reboot-> check for update -> install -> reboot-> check for update). So I cannot say which update exactly has changed this value.
