[fixed]Double extension filtering exception
BOOZy
Post by BOOZy »
Hello all.
We're having a bit of a problem with the filtering rule for double extensions (eg. .pdf.exe).
The rule is a bit too strict. Let me elaborate on this.
Our company name is 'Company.net'.
Quite often we get attachments -usually PDF- which are auto-generated as companyname.pdf, thus resulting in company.net.pdf
I guess you can see the problem there.
Is it possible to create an exception on the rule? As it is now it seems to be a blanket ban on anything that vaguely looks like a double extension.
Edit1: added fixed tag
Edit2: meta tags:
Bad Content
Blocked File: Y
Report: MailScanner: Attempt to hide real filename extension ( .net.pdf)
Re: Double extension filtering exception
edit /etc/MailScanner/filename.rules.conf
search for "double file extensions" and comment out the rule below it. This rule is the generic rule.
alternatively, you can add a rule specifically to allow certain double extensions in while denying the rest
e.g.
allow \.pdf\.exe
I don't know if you need to restart the mailscanner service afterwards, but it cannot hurt.
BOOZy
Post by BOOZy »
I had to tweak it a bit but eventually I got it to work.
allow	.\net\.pdf	-	-
