Only 66mb in VAR !!
bas60
Only 66mb in VAR !!
Post by bas60 »
How do I clear used up space in VAR
I changed the message retention from 60 > 30 and now to 7
I 've run mailwatch_db_clean.php twice and rebooted
still around 60mb
What am i doing wrong ???
TheGr8Wonder
Re: Only 66mb in VAR !!
Post by TheGr8Wonder »
While logged into MailWatch, can you take a snippet of the "Free Disk Space" at the top-center of the page and post here? We want to see how your system was carved up.
bas60
Post by bas60 »
2 children
postfix 4 proc
1min 0.00
5min 0.03
15min : 0.02
Inbound :0
Outbound: 5
/ 4.66Gb [60%]
/boot 312.47Mb [65%]
/tmp 913.59 [94%
/var 61.47MB [0%]
What's your MailScanner quarantine retention in /etc/MailScanner/defaults ?
What happens when you run this?
/usr/local/bin/mailwatch/tools/Cron_jobs/mailwatch_quarantine_maint.php --clean
bas60
Post by bas60 »
only thing obvious is q_days=0
does that mean it not going to delete any !!??
No, actually, it should be 0. Just wanted to double check. eFa uses MailWatch instead to handle this....
MailWatch should be purging items based on QUARANTINE_DAYS_TO_KEEP. How far back can you see in /var/spool/MailScanner/quarantine folders?
bas60
Post by bas60 »
Ok
that seems have freed up 13Gb
I forgot I set q_days=7 before I run the command !
THANK YOU
Justin
Post by Justin »
I'm having the same issue at the moment.
44mb left on /var
/var/lib/mysql/mailscanner has a file name maillog.ibd which is 23.6 GB
Is there a way to shrink this?
Justin wrote: 11 Jan 2019 09:51 I'm having the same issue at the moment.
44mb left on /var
Reduce this number here...
// Define how many days of emails to keep.
define('RECORD_DAYS_TO_KEEP', 60);
