Greylisting Whitelist
Posted: 24 Feb 2020 17:51
Dear All,
Lately been having issues with Grey listing, when customers email us from Office 365 takes ages untill its arrives.
So we decieded to start using Grey listing white listing.
let start
Step 1.
let create a file called clients_fqdn_whitelist.local on the sqlgrey listing
Step 2
let add the domains that will not be added to the sqlgrey listing scan
Step 3
run sudo update_sqlgrey_config after add the domains to the list
Step 4
this is very important step to get the sql database check the domains. you have to restart the sqlgrey
to add domains in the future, just add the doam and follow steps 2 till 4.
if you have any questions let us know.
let start
Step 1.
/etc/sqlgrey/clients_fqdn_whitelist.local
Domain.com
domain.net
jamesbond.com
sudo systemctl restart sqlgrey
