new Plugin [sadwl]
Posted: 13 Jun 2019 09:05
by nicola.piazzi
sadwl is a simple plugin that i made now
It create a sql table that have a list of combination fromdomain + reverse sender host domain
You can see this table using a table browser in Windows connected to efa MySQL and give a bonus or penality to each domain !
This plugin is very simple to install, unzip the contents of sadwl.zip into /etc/mail/spamassassin and run sadwl.inittable.sh to create table
Then download and connect this table sadwl using for example Database Browser, you can get it here :
https://www.etl-tools.com/database-brow ... rview.html
(this can be used also for other db on other machines)
Now you can see received email usage and give a score to future mails received from combinations
Pay attention to not give too much bonus to freemail domains !!!
Here a sample from my table
Re: new Plugin [sadwl]
Posted: 13 Jun 2019 09:45
I'm sorry can you quickly explain what exactly this is: "reverse sender host domain"?
Do you take the IP of the sending server and do a reverse DNS lookup?
Posted: 13 Jun 2019 10:32
by nicola.piazzi
yes
Posted: 14 Jun 2019 14:41
by nicola.piazzi
New release correct a bug that doenst update after user assigning score
then added table maintanence that delete older record with low hiots and no score assigned
Posted: 15 Nov 2019 09:42
shawniverson,
Nicola has created a number of plugins that might be worth bundling (even if disabled by default) with the default v4 EFA.
Posted: 15 Nov 2019 13:40
by nicola.piazzi
