new Plugin [sadwl]
new Plugin [sadwl]
Post by nicola.piazzi »
sadwl is a simple plugin that i made now
It create a sql table that have a list of combination fromdomain + reverse sender host domain
You can see this table using a table browser in Windows connected to efa MySQL and give a bonus or penality to each domain !
This plugin is very simple to install, unzip the contents of sadwl.zip into /etc/mail/spamassassin and run sadwl.inittable.sh to create table
Then download and connect this table sadwl using for example Database Browser, you can get it here :
https://www.etl-tools.com/database-brow ... rview.html
(this can be used also for other db on other machines)
Now you can see received email usage and give a score to future mails received from combinations
Pay attention to not give too much bonus to freemail domains !!!
Here a sample from my table
sadwl.zip
(3.62 KiB) Downloaded 606 times
ovizii
Re: new Plugin [sadwl]
Post by ovizii »
I'm sorry can you quickly explain what exactly this is: "reverse sender host domain"?
Do you take the IP of the sending server and do a reverse DNS lookup?
yes
New release correct a bug that doenst update after user assigning score
then added table maintanence that delete older record with low hiots and no score assigned
sadwl.r2.zip
(3.84 KiB) Downloaded 601 times
shawniverson,
Nicola has created a number of plugins that might be worth bundling (even if disabled by default) with the default v4 EFA.
