Rewrite Sender Address Postmaster + Apache
Slushell
Post by Slushell »
i hope someone can help me.
How do i define which sender address is used for apache@domain and postmaster@domain, or is there a way to masquerade them, because if i release a non-spam those two addresses are rejected by the mail provider since they are not resolvable (local lan/domain).
I am running latest version 3.0.0.7
Thanks in advance.
Alex
Slushell
Re: Rewrite Sender Address Postmaster + Apache
Post by Slushell »
Found the Solution my Self.
You can edit the Sender address in /var/www/html/mailscanner/conf.php
Greetings.
