Use of uninitialized value $hasStructureInfo in numeric eq
MauriceW
Post by MauriceW »
After upgrading to 3.0.0.7 I can no longer do an SA Learn "Spam + Report" on a false negative. I get this error in the web interface:
SpamAssassin: Mar 11 00:19:11.077 [25979] warn: Use of uninitialized value $hasStructureInfo in numeric eq (==) at (eval 34) line 5520., 1 message(s) examined.
Is there a way to fix this?
ashweb
Re: Use of uninitialized value $hasStructureInfo in numeric eq
Post by ashweb »
I had this issue with a system running 3.0.0.7 but it was resolved with the update to 3.0.0.8 which failed initially on ClamD but was resolved by the commands at the bottom of this post viewtopic.php?f=13&t=1096&hilit=update+ ... t=25#p4105
