How-to check E.F.A.-Version (with a monitoring tool)
DaN
Post by DaN »
This is a simple and dirty way to check the local E.F.A. version number against the newest available version with a monitoring tool like nagios, icinga, Shinken, or ...
It's usefull if you don't use the auto update mechanism of E.F.A.
Don't use the script if the webserver is reachable from the internet.
E.F.A.-Server:
EFA-Version-Check.php in /var/www/html
<?php
 * Simple and dirty php script to check if the local E.F.A. (http://efa-project.org/) version is up to date.
 * This script only works on the E.F.A. server (/var/www/html).
 * Do not use this script if this E.F.A. webserver is reachable from the internet.
 * Do not use this script every 10 minutes. Done twice per workday is more than enough! Configure your monitoring tool correct!
 * CC BY-SA
 * @version: 0.3
 * @author: DaN@EFA, pdwalker
 * @changelog:
 * 0.1:initial version
 * 0.2:trim-fix from pdwalker
 * 0.3:additional trim-fix
 * CONFIGURATION
 * localVersionFile: set the full path to the "EFA-Version" file
 * remoteVersionUrl: set the link to the "EFA-Version" file from the E.F.A update server
 * To test the output from "file_get_contents" just uncomment the echos (line 28 and 32), test and comment it out again
$localVersionFile = "/etc/EFA-Version";
$remoteVersionUrl = "http://dl.EFA-project.org/update/EFA-Version";
// get local E.F.A. Version
$localEFAVersion = trim(file_get_contents($localVersionFile));
// echo "Local: $localEFAVersion";
// get remote E.F.A. Version
$remoteEFAVersion = trim(file_get_contents($remoteVersionUrl));
// echo "Remote: $remoteEFAVersion";
// compare and return info
if ($localEFAVersion == $remoteEFAVersion) {
	echo "local version $localEFAVersion is up-to-date";
	exit (2);
else {
	echo "a new version is available: $remoteEFAVersion";
is available via https://[E.F.A. servername or IP]/EFA-Version-Check.php
Monitoring Server:
command definition (e.g. http.cfg or commands.cfg):
# 'check_http_with_string' command definition
define command{
	command_name    check_http_with_string
	command_line	/usr/lib/nagios/plugins/check_http -H '$HOSTADDRESS$' -u '$ARG1$' -s '$ARG2$'
service definition (e.g. EFA-Server.cfg):
define service{
	use                             	generic-service         ; Name of service template to use
	host_name                       	EFA-Server
	check_period			workhours
	check_interval			300
	service_description            E.F.A.-Version
	check_command                check_http_with_string!/EFA-Version-Check.php!up-to-date
:?: [Monitoring tool] calls the php-file, php-file compares version files, the output is a string, the string is checked. If this string doesn't contain "up-to-date" the status should be "CRITICAL".
darky83
Site Admin
Re: How-to check E.F.A.-Version (with a monitoring tool)
Post by darky83 »
:text-goodpost:
Nice post, that is a good idea :)
DaN
Post by DaN »
update:
/etc/EFA-Version (3.0.0.9) has a space/blank at the end
or you could change
$localEFAVersion = file_get_contents($localVersionFile);
to
and not worry about it.
BDKaatz
Post by BDKaatz »
Greetings,
I have another update for you...
If you are running the E.F.A. server with https, enter the following command definition into commands.cfg:
define command{
   command_line   /usr/lib/nagios/plugins/check_http -H '$HOSTADDRESS$' -u '$ARG1$' -s '$ARG2$' --onredirect=follow
Since the http request will get a 302 response to redirect to https, you want to follow it to the EFA-Version-Check.php page. Of course, you can use the "sticky' directive instead of 'follow', if you wish.
HTH. And, thanks again for this, DaN.
________________________
"I do not feel obliged to believe that the same God who has endowed us with
sense, reason, and intellect has intended us to forgo their use."
-- Galileo Galilei
DaN
Post by DaN »
@BDKaatz - thx for the update
For those of you who get error 403 (Access denied) with the new integrated mod_security (EFA <= 3.0.1.9)
could add
SecRuleRemoveById 960015
to
/etc/httpd/conf.d/mod_security.conf
at the end before last </IfModule>
to work around the problem.
