Forgive the silly questions, but I seem to be unclear on a few concepts regarding EFA:
- Does EFA require a user account for every incoming email address in the domain protected, or are EFA user accounts uniquely for admin use?
- I see elsewhere in the forums, that it possible to have EFA validate destination email addresses against an LDAP directory before accepting an inbound message; is this a one time import, or is it an ongoing, real-time validation?
- How/where are RBL set (i.e. can we check the sending server's IP against zen.spamhaus.org et al?
- Is there any way to quickly build a working ham/spam database, or is this something that gets built only by users clicking on the "this is spam" link at the bottom of incoming messages?
- Is there any documentation that outlines the flow if inbound message processing (i.e. greylist before/after RBL before/after SPAM check, etc...)
Sorry for the very basic questions, but I couldn't find the answers anywhere.
Thanks in advance for your answers!
Newbie questions...
Re: Newbie questions...
No, EFA does not require a user account for every user. Users that do not have an account cannot manage their own quarantine.Does EFA require a user account for every incoming email address in the domain protected, or are EFA user accounts uniquely for admin use?
It is a common misconception that EFA's user database in mysql also does validation. User validation must be done in postfix, and can be accomplished manually or with a cron script.I see elsewhere in the forums, that it possible to have EFA validate destination email addresses against an LDAP directory before accepting an inbound message; is this a one time import, or is it an ongoing, real-time validation?
That's what the bayesian database is for, and yes, you will need to "train" it either manual or with a corpora of spam/ham using the sa-learn command.Is there any way to quickly build a working ham/spam database, or is this something that gets built only by users clicking on the "this is spam" link at the bottom of incoming messages?
No, but this is a great idea. I may draw up a flowchart.Is there any documentation that outlines the flow if inbound message processing (i.e. greylist before/after RBL before/after SPAM check, etc...)
OK, so do I understand correctly that a single admin can control the quarantine for all the users in that domain? How much of a load would this be for the admin?No, EFA does not require a user account for every user. Users that do not have an account cannot manage their own quarantine.
Would it be possible then to adjust the "spamminess" of mail to only quarantine the very worst spam, even if this means letting some thru?
The upside of not creating accounts for all users is ease of use for them, but what is the downside?
OK. This still seems to be an awkward process. Doesn't postfix have a way to automatically validate inbound recipients using either an separate SMTP connection to the downstream server, or using an LDAP lookup to check the email address before accepting an inbound message? Is this possible with EFA?It is a common misconception that EFA's user database in mysql also does validation. User validation must be done in postfix, and can be accomplished manually or with a cron script.
Are all of postfix's configs contained in /etc/postfix?
Can the ham corpus be developed by routing all outbound mail thru EFA and using that as an input to sa-learn? Ideally this would be an ongoing process, improving the ham database with every outbound message.That's what the bayesian database is for, and yes, you will need to "train" it either manual or with a corpora of spam/ham using the sa-learn command.
Do users that don't have an account get the "this is spam" link on their mail?
Other that clicking on the "this is spam" link, how does the spam corpus get built?
I'm really looking forward to your flowchart as I'm a bit lost as to exactly what app is doing what in EFA. I found this site that describes a MailServer setup using LDAP that has a pretty good diagram to start with. http://acidx.net/wordpress/2014/06/inst ... roundcube/No, but this is a great idea. I may draw up a flowchart.
Thanks in advance for answering these very newbie questions.
Have a look at the mailscanner document on page 24 of the MailScanner User Guide and Training Manual at http://www.mailscanner.info/files/MailScanner-Guide.pdf
It contain's a flowchart that should be mostly correct for EFA (since EFA is based on Mailscanner). Also keep in mind that the MTA (postfix) may be doing some other checks before accepting any mail.
@pdwalker
This is a big help understanding how mail is passed thru EFA.
Thanks very much.
For reference, here is a link to that image: https://www.dropbox.com/s/ufufj7iasvyxn ... t.png?dl=0
Thanks very much.
Keep in mind that it doesn't show where SQLGrey goes which I believe is part of the MTA process at the very start.
