We would also like to thank everyone for their support and contributions to this project.
The following issues have been fixed in 3.0.0.7:
Issue #30 Enhancement - Filter out nonspam in quarantine reports (regression fix)
Issue #82 Enhancement - re2c spamassassin rule complilation support
Issue #128 Enhancement - Adjust Treat Invalid Watermarks With No Sender as Spam
Issue #133 Enhancement - Upgrade spamassassin to 3.4.0
Issue #136 Enhancement - Disable Notify Senders by default in MailScanner
Issue #139 Bug - SSLv3 POODLE Vulnerability
Issue #138 Enhancement - Maximum Processing Attempts Database Adjustments
Issue #141 Enhancement - Exclude Whitelisted Emails from Report as Spam Link
Issue #145 Bug - Modify Domain TLD Constraint
Issue #147 Bug - Message Learn/Release Rejecting 8 digit ID prefix
Issue #149 Bug - Disable SSL in Postfix (POODLE)
Issue #151 Bug - Fix for issue #141 for inbound whitelisted emails only
Issue #152 Bug - Fix for Issue #136 fix
Issue #153 Bug - Reply signature behavior not functional
Issue #154 Bug - Fix Razor typos in build.bash
Issue #155 Bug - GHOST Vulnerability in glibc
We encourage everyone to update.
If you have auto update enabled your system will automatically update to this new release.
If you have auto update disabled you will need to run the update command manually.
1) login to your box with ssh
2) press ’1′ to get an shell
3) type:
sudo /usr/local/sbin/EFA-Update -updatehttps://github.com/E-F-A/v3/blob/3.0.0.7/RELEASENOTES
Stay tuned for new VM builds!
