run quarantine report for 1 user
Posted: 12 Feb 2015 21:28
by cdburgess75
Can I run the report for a certain user only?
Re: run quarantine report for 1 user
Posted: 14 Feb 2015 16:34
No, but that would be easy to implement.
The /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php script would need modified to accept a single user...
Posted: 17 Feb 2015 11:35
by colin
Yes. If you create a user with the username
username@domainname.com and select that you want to generate reports, that will generate a report just for that email address.
Posted: 18 Feb 2015 11:55
colin wrote:Yes. If you create a user with the username
I'm stuck in the command line world....
Posted: 02 Apr 2015 10:11
by Socal_Steve
It's the best place to be! always makes me laugh
Posted: 02 Apr 2015 18:58
by darky83
I've got an T-shirt with that image on it
(thingeek)
