installing EFA on a VPS
Posted: 19 Jan 2015 10:26
by doggy101
Hi All,
is it possible to install efa on a VPS where you have to to select a distro from a list f.i. leaseweb or Contabo.
what I'm looking for is a script to run after the default OS is installed...
I have been using Efa and ESVA for ages but allways on my VMWare servers and now I have to move to a VPS for the mailscanner to get the needed securety risk spreading
Re: installing EFA on a VPS
Posted: 21 Jan 2015 12:23
If you can install CentOS 6.6, then yes, you can install EFA on a VPS using the install efa without ks script on github.
Posted: 21 Jan 2015 12:27
by doggy101
thanks, can you give me some links for that?
Posted: 21 Jan 2015 12:30
Posted: 27 Jan 2015 21:05
by doggy101
okay got it installed but the config did not start, what is the command to configure?
Posted: 27 Jan 2015 21:47
by doggy101
nevermind :-) it's rebooting now and starting with the efa configure...
Posted: 29 Jan 2015 07:54
by doggy101
all working except the releasing of messages...
Software error:
Error in id syntax at /var/www/cgi-bin/release-msg.cgi line 105.
For help, please send mail to the webmaster (root@localhost), giving this error message and the time and date of the error.
Posted: 29 Jan 2015 15:55
by darky83
Can you post your release link?
Posted: 29 Jan 2015 18:59
by doggy101
If you are satisfied that this message is not spam, you can release it from quarantine
by clicking http://efamailscanner.bikkernet.nl/cgi- ... 3287809f49
Posted: 29 Jan 2015 21:11
Darky,
This user may be post 3.0.0.6. Is there possibly a syntax error in the master branch for this line?
Posted: 29 Jan 2015 22:04
by doggy101
I Used the above named script :-) from github..
Posted: 30 Jan 2015 16:43
by doggy101
when "reporting as spam" from the URL in the mail is working fine...
Posted: 01 Feb 2015 23:55
8 digit ID prefix...it appears....fixing....
https://github.com/E-F-A/v3/issues/147
