Is there anybody else running EFA on Proxmox VE, I have converted the Hyper-V disc file to qcow2 for KVM (QEMU) on my proxmox.
So if anybody else would like to get a copy, then tell me, and I can share it.
Best Regards
Søren Ressel
proxmox (KVM)
Re: proxmox (KVM)
did the same. running well for a couple weeks now. thanks!
c0mputerking
Re: proxmox (KVM)
Yep i'm using proxmox too but i just did a complete install on centos i think cant quite remember, but never really had much luck with converting image files
Re: proxmox (KVM)
Hello Søren Ressel,
Actually, i use EFA on Hyper V, and it run perfectly.
I have a project for a customer to install EFA on Proxmox, and i'm very interesting to have a copy if you want to share.
Thanks very much !
Knarou
Thanks very much !
Knarou
Re: proxmox (KVM)
Hello, just wanted to offer that the system runs quite well on ProxMox. I converted the vmdk file with the command:
qemu-img convert Email_Filter_Appliance-disk1.vmdk -O qcow2 emailappliance.qcow2
attached the new image to a standard VM config and I was off to the races.
Re: proxmox (KVM)
Offtopic, but what's your opinion on proxmox? I've recently tried vmware server 6.5 and it's been... awful. My previous kvm/qemu installation has been more stable and faster than vmware 6.5. Sad.
