552 5.3.4 Message size exceeds fixed limit
Posted: 09 Jan 2015 11:07
by jotaerre
I'm getting this error from an 7MB email.
The size rule from MailScanner has no limit, i can't find the limit rule.
Help please?
Jota
Re: 552 5.3.4 Message size exceeds fixed limit
Posted: 10 Jan 2015 10:53
by MauriceW
It's the message size limit in Postfix.
You should edit the file /etc/postfix/main.cf and change the parameter message_size_limit to what you want the limit to be (specified in bytes).
Posted: 14 Jan 2015 22:28
by jotaerre
The parameter isn“t there.
I've included it.
I'll check to see if it works.
