Hi, I'm new and I'm trying EFA, but I have problems logging by WEB since I updated to version 3.0.0.6 but when entering tells me my username and / or password is wrong, but if I can enter through SSH
I hope they can support me and I do not know much about Linux.
Regards
MailWatch Login not enter
Re: MailWatch Login not enter
You can reset your mailwatch password if you can gain access to mysql.
Look in /etc/EFA-Config for you mysql password for mailwatch
Execute the following:
Exclude the < >'s above
/usr/bin/mysql -u mailwatch -p<mailwatchpwd> mailscanner -e "UPDATE users SET password = md5('<yourpassword>') WHERE user='<yourusername>'"-
nitromuzic
hi, thanks for the reply
I tried to make as indicated but I get an error.
I'm on the server itself with the user root
EFA-Config
EFA-Config
- efa2.jpg (50.26 KiB) Viewed 9195 times
Oh, my bad, change the username to "mailwatch"
