Domaincheck did not support the new TLD "consulting"
Posted: 25 Nov 2014 20:44
the domaincheck accept only TLD with max 6 letters. "consulting" has 10 letters.
I found on github : v3 / build / EFA / lib-EFA-Configure / func_mailsettings
line 90, 129, 168, 208 a domain check:
should be replaces by
- Dromaius
if [[ $DOMAIN =~ ^[a-zA-Z0-9]+([\-\.]{1}[a-zA-Z0-9-]+)*\.[a-z]{2,6}$ ]];Code: Select all
if [[ $DOMAIN =~ ^[a-zA-Z0-9]+([\-\.]{1}[a-zA-Z0-9-]+)*\.[a-z]{2,10]$ ]];- Dromaius
