3.0.0.6
I've tried to use "SA Learn" "As Spam" and the "Result Message" is "cannot open /etc/mail/smapassassin/KAM.cf". Which user is used to open the .cf?
Is it a bug or do i misunderstood the function?
[SOLVED] SA Learn as Spam: error KAM.cf
- SA Learn as SPAM
- Unbenannt.PNG (37.84 KiB) Viewed 5647 times
Re: SA Learn as Spam: error KAM.cf
The mode on my my KAM.cf is 644.
The permissions on your KAM.cf do not look right....They should be rw- r-- r-- (644)
Thanks. "644" was the answer I've searched for. I don't think this is a bug so the thread can be moved to "Discussion".
