Versions
Posted: 30 Oct 2014 23:51
by drewmorris
Just a quick question... I noticed the announcement about 3.0.0.6 but I noticed on the download page the images are all 3.0.0.5... is there a reason for this? Shouldn't these be updated?
Re: Versions
Posted: 31 Oct 2014 08:23
by darky83
3.0.0.6 was an emergency update, and I just havn't had the time to create new VM images
Re: Versions
Posted: 31 Oct 2014 15:30
by drewmorris
So does using the 3.0.0.5 with the automatic updates turned on achieve the same result?
Re: Versions
Posted: 31 Oct 2014 18:56
by darky83
Yep, it will automatically update to the latest version.
