[SOLVED] Read-Receipt missing with Zimbra 8.0.7
Posted: 30 Oct 2014 22:47
Hi to all!
Like Subject, i set efamx as MTA relay on my Zimbra 8.0.7 server. if i send mail with Read-Receipt, efa purge header and remove the Read-Receipt TAG.
Anyone as the same problem or there is a way to solve this issue?
thanks and regards
thanks and regards
