E.F.A. 3.0.0.6 update released
Important news
Locked
darky83
Site Admin
Post by darky83 »
The 3.0.0.6 update is now available, this 'emergency' update is needed to update the bash security issues as soon as possible.
We would also like to thank everyone for their support and contributions to this project. :clap:
The following issues have been fixed in 3.0.0.6:
  • Force yum update to fix bash security issues
  • Issue #127 Bug - Greylisting not toggling on 3.0.0.5
  • Issue #129 Enhancement - Increase max spam check size to 2 MB
  • Issue #130 Bug - Quarantine report problems after 3.0.0.5 upgrade
  • Issue #131 Bug - Undefined index %orgname%
  • Mailwatch updated to snapshot 7f6858df83
We encourage everyone to update.
If you have auto update enabled your system will automatically update to this new release.
If you have auto update disabled you will need to run the update command manually:
1) login to your box with ssh
2) press ’1′ to get an shell
3) type:
You can download the latest VM image version from http://efa-project.org/download
Locked
