How To Mass Import Whitelists and Blacklists
Post by shawniverson » 21 Sep 2014 19:40
Mass import script is now available here:
https://raw.githubusercontent.com/E-F-A ... timport.sh
To download:
wget https://raw.githubusercontent.com/E-F-A/v3/master/tools/listimport.sh
chmod ugo+x userimport.sh
EFA Mass Whitelist and Blacklist Import Help
listimport.sh Copyright (C) 2014 efa-project.org
Licened GNU GPL v3. This program comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it under
certain conditions. See http://www.gnu.org/licenses for more details
Usage: listimport.sh -f mylist -b|-w [-a|-o [-q]]
-f Whitelist or Blacklist File
-a append to existing list
-b File is a Blacklist
-q force overwrite database tables without prompting
-o overwrite existing list
-w File is a Whitelist
Whitelist and Blacklist is newline separated list with each
line in either of the following formats:
<From Address Domain or IP>, <To Address Domain or IP>
Examples:
sudo /path/to/listimport.sh -f /path/to/mywhitelist.txt -a -w
sudo /path/to/listimport.sh -f /path/to/myblacklist.txt -a -b
Use the overwrite feature with caution. Always back up prior to executing your mass import.
SupportOU
Re: How To Mass Import Whitelists and Blacklists
Post by SupportOU » 17 Feb 2017 15:19
Hola!
Is there also a mass export functionality??
Grtz,
Ronald
Post by shawniverson » 17 Feb 2017 23:33
Should be pretty straightforward.
enricosx
Post by enricosx » 29 Mar 2018 12:08
thanks for yours hard work.
what is the correct syntax?
domain.com
or
*domain.com
or
*@domain.com
Post by shawniverson » 05 Jan 2019 18:48
Wildcards should not be used.
