Update to 3.0.0.5 is pending > not running latest kernel
Mr. Happy
Post by Mr. Happy »
When I try to update EFA I get the following error
Update to 3.0.0.5 is pending.
Your system has an updated kernel, but you are not running
on the latest kernel.  Please restart your system and run
EFA-Update after restart.
Unfortunately, rebooting and rerunning the update doesn't solve it. I keep getting these errors.
darky83
Site Admin
Re: Update to 3.0.0.5 is pending > not running latest kernel
Post by darky83 »
That is weird, after an reboot the update should install again.
If you run
EFA-Update -check
does it shows you there is an update available ?
Also can you send me the output from the following 2 commands?
grep -m 1 CentOS /boot/grub/menu.lst | sed 's/.*(//' | sed 's/)//'
and:
uname -a
Mr. Happy
Post by Mr. Happy »
EFA-Update -check gives me
[EFA] Getting latest version number from http://dl.efa-project.org
[EFA] You are running EFA version EFA-3.0.0.4
[EFA] Latest version update is EFA-3.0.0.5
the grep returns:
2.6.32-431.29.2.el6.x86_64.debug
uname -a
Linux <hostname> 2.6.32-431.29.2.el6.x86_64 #1 SMP Tue Sep 9 21:36:05 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
darky83
Site Admin
Post by darky83 »
it seems you have enabled debug kernels?
yum list installed | grep -i kernel
I guess you have enabled kernel-debug-devel
Mr. Happy
Post by Mr. Happy »
Apparently I have.. :?
abrt-addon-kerneloops.x86_64
dracut-kernel.noarch
kernel.x86_64       2.6.32-431.5.1.el6  @updates
kernel.x86_64       2.6.32-431.11.2.el6 @updates
kernel.x86_64       2.6.32-431.17.1.el6 @updates
kernel.x86_64       2.6.32-431.20.3.el6 @updates
kernel.x86_64       2.6.32-431.29.2.el6 @updates
kernel-debug.x86_64 2.6.32-431.11.2.el6 @updates
kernel-debug.x86_64 2.6.32-431.17.1.el6 @updates
kernel-debug.x86_64 2.6.32-431.20.3.el6 @updates
kernel-debug.x86_64 2.6.32-431.29.2.el6 @updates
kernel-debuginfo.x86_64
kernel-debuginfo-common-x86_64.x86_64
kernel-devel.x86_64 2.6.32-431.5.1.el6  @updates
kernel-devel.x86_64 2.6.32-431.11.2.el6 @updates
kernel-devel.x86_64 2.6.32-431.17.1.el6 @updates
kernel-devel.x86_64 2.6.32-431.20.3.el6 @updates
kernel-devel.x86_64 2.6.32-431.29.2.el6 @updates
kernel-firmware.noarch
kernel-headers.x86_64
libreport-plugin-kerneloops.x86_64
How can I disable/remove them??
darky83
Site Admin
Post by darky83 »
yum remove kernel-debug.x86_64
But the question is more, why are they installed :think:
They should not have been installed by any normal E.F.A. update so i'm confused :shifty:
Mr. Happy
Post by Mr. Happy »
Thanks.. That solved it...
But for the life of me, I don't recall installing it (or for what reason)... :oops:
