Internal Server Error
rshellhamer
Post by rshellhamer »
All was working until update to 3.0.0.5 was applied.
No from Non-Spam Emails if you click on the link, Click here to report this message as spam, i get an internal server error.
Here is an example of the error:
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, root@localhost and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Re: Internal Server Error
Confirmed... :o
Debugging...
Permissions problem. Please execute the following on your EFA to fix:
sudo chmod ugo+x /var/www/cgi-bin/*
Committing fix to 3.0.0.5 branch.
Thanks for feedback :D
rshellhamer
What you had suggested has fixed the issue. Thanks :D
