E.F.A. 3.0.0.5 update released
Important news
Locked
darky83
Site Admin
Post by darky83 »
The 3.0.0.5 update is now available, some time has been put into this update to fix a bunch of bugs we noticed in earlier versions.
We would also like to thank everyone for their support and contributions to this project. :clap:
The following issues have been fixed in 3.0.0.5:
  • Issue #33 Enhancement - Remove software versions page from mailwatch
  • Issue #51 Enhancement - Redundant Quarantine Clean Scripts Present
  • Issue #54 Enhancement - Added hostname change to EFA-Configure
  • Issue #57 Enhancement - Alternating background for black/whitelist
  • Issue #66 Enhancement - Pull passwords from /etc/EFA-Config where practical
  • Issue #67 Enhancement - ImageCeberus default score
  • Issue #69 Bug - Filter out reserved words from user account creation
  • Issue #70 Enhancement - .bashrc EFA-Configure Launch Interactive Only
  • Issue #71 Bug - Urgent: raw.github.com certificate error fixes
  • Issue #73 Bug - Admin Email Change Fails to Update MailScanner Values
  • Issue #74 Bug - EFA-Configure Disable SSL does not disable redirect
  • Issue #75 Bug - EFA-Configure not writing iptables config to /etc/sysconfig/iptables
  • Issue #76 Bug - Processing Attempts Database Bug (temporarily disabled until MailScanner releases fix)
  • Issue #77 Bug - EFA MailScanner 0 byte tmp files (patched until MailScanner releases fix)
  • Issue #79 Enhancement - EFA-Update Staging and Error Handling
  • Issue #85 Bug - ClamAV Update Issue
  • Issue #87 Bug - EFA-Tokens-Cron Syntax Wrong
  • Issue #89 Bug - Razor errors in MailWatch Gui
  • Issue #90 Bug - Reapply 3.0.0.4 Update Fixes
  • Issue #93 Bug - Pyzor Errors
  • Issue #94 Bug - Postfix ID Regex Double Check
  • Issue #95 Bug - SASL Authentication database not found (dummy file created)
  • Issue #98 Bug - postfix tlsmgr smtpd_tls_session warnings
  • Issue #101 Bug - Can't register IDN names (hopefully fixed)
  • Issue #102 Enhancement - Remove raid-check cron
  • Issue #103 Bug - Update EFA-Init mirror path
  • Issue #104 Bug - Can't define multiple transports for same domain in efa-configure
  • Issue #107 Bug - MailWatch login page shows Mailwatch logo and theme after update testing
  • Issue #108 Bug - lists.php fails to load after MailWatch update testing
  • Issue #109 Bug - Documentation tab present after MailWatch update testing
  • Issue #110 Bug - Bring MailWatch conf.php to latest version
  • Issue #111 Bug - MailWatch.pm Errors after adding password fetch code
  • Issue #113 Bug - Modify EFA-Init to check a variable inside EFA-Config
  • Issue #115 Bug - Greylist option not available in new mailwatch version
  • Issue #116 Bug - Token is missing in 3.0.0.5
  • Issue #117 Enhancement - Lower High spamassassin score from 10 to 7
  • Issue #119 Bug - /etc/init.d/vmtoolsd: Permission denied
  • Issue #120 Bug - EFA-Configure System Restore showing all files
  • Issue #123 Enhancement - Update Kernel, mysql, postfix, clamav, clamd
  • Issue #124 Bug - MailScanner dies after update to 3.0.0.5
We encourage everyone to update.
If you have auto update enabled your system will automatically update to this new release.
If you have auto update disabled you will need to run the update command manually:
1) login to your box with ssh
2) press ’1′ to get an shell
3) type:
You can download the latest VM image version from http://efa-project.org/download
Locked
