Out of office replies and Undeliverables
Posted: 07 Aug 2014 14:25
by Netman
Hi.
For some reason, undeliverable messages received from lots of server as well as Out of office replies shows up in EFA with no sender. Then EFA flags them as spam. Reason given is "(no watermark or sender address)"
What can I do to allow messages with no sender to be received ?
BTW. I'm really impressed by the performance of the product. Cheers to you all !
Re: Out of office replies and Undeliverables
Posted: 07 Aug 2014 17:04
by darky83
We have heard of this problem before, but never been able to re-produce it to see where the issue is.
Are you able to send a part of the mail log from one of the failing messages?
Also the full message e-mail that is marked as spam could be usefull.
Posted: 07 Aug 2014 17:10
by Netman
I don't have the log, but I do i have one message.
Where would I send it ?
Posted: 08 Aug 2014 00:22
Actually, I may have your solution...
Try modifying the following line in /etc/MailScanner/MailScanner.conf as follows:
Treat Invalid Watermarks With No Sender as Spam = 2
These type of emails seem to get the watermark stripped from them on the remote side with some types of email servers. Setting this value below your spam threshold will treat these emails with suspicion but not automatically flag them as spam unless other triggers occur.
Don't forget to restart mailscanner...
Posted: 04 Sep 2014 13:15
by Netman
Sorry for the delay....
Testing !
I'll get back to you soon....
Posted: 02 Mar 2015 14:53
by rvh
Netman wrote:Hi.
I am having the same problem with release 3.0.0.7
Posted: 02 Mar 2015 17:26
by rvh
I have the same problem with release 3.0.0.7
I have checked setting "Treat Invalid Watermarks With No Sender as Spam = 2" but it is the default setting.
Is there an other work arround to solve this problem?
rvh
Posted: 02 Mar 2015 18:50
You could completely disable this setting and see what happens
Treat Invalid Watermarks With No Sender as Spam = 0
Posted: 02 Mar 2015 20:13
by rvh
Hi shawniverson,
I give it a try and let you know the result.
Meanwhile, I also searched the internet for a solution and I've found several advices to set "Use Watermarking = no"
Posted: 02 Mar 2015 20:18
Yes, both settings would have the same effect
Posted: 03 Mar 2015 16:55
by rvh
Hi shawniverson,
I have changed the setting 'Treat Invalid Watermarks With No Sender as Spam = 2' to 0 and now it's all working well!
Thanx!
rvh
