Cannot release mails
Hi !
I migrated from ESVA to EFA yesterday. I cannot release SPAM mails. If I try to release a mail, I get another mail like this
Our UCE (spam) detectors have been triggered by a message you received:-
There seems to be a mail loop, the mail I want to release is scanned and quarantined again.
Any ideas?
thanks,
jokr
Any ideas?
thanks,
jokr
Re: Cannot release mails
Looks like somehow localhost is not whitelisted.
Make sure that 127.0.0.1 to default is on the whitelist and restart mailscanner.
Thanks, this is probably the solution, I imported Whitelist and Blacklist via MYSQL DUMP from ESVA and lost this Entry.
What do you mean by 127.0.0.1 to default ?darky83 wrote:Looks like somehow localhost is not whitelisted.
I also cannot release mails, but I don't get another mail.
Also I cannot view mails in the quarantine folder.
What I do get is the following errors in the httpd error log:
PHP Notice: Undefined index: %orgname% in /var/www/html/mailscanner/functions.php on line 1261
Yes, we have an open bug on this.
You can fix manually by editing the following:
Change
To:
Change
Watermark Secret = %orgname%-<random characters>
Watermark Secret = %org-name%-<random characters>
Does that bug also contain that I cannot view the contents of the mail in the webinterface?
I am not seeing this issue, you should be able to view mail contents.
Can you give me more details?
What happens when you click to view the contents?
Any error messages in the Apache log files?
nvm...
found it...
Somehow the line
was changed to
found it...
Somehow the line
Quarantine Whole Messages As Queue Files = yes
I've had this problem with a fresh install of EFA. Problems it caused:
- Viewing email previews in mailscanner (eg showed nothing)
- Releasing messages via mailscanner were delivered in a corrupted format.
Be aware that the change only applies to new messages, you can still view the old messages with vim, etc.
Best way for end users to view them is by changing the extension to .html
