add domain
rpw
add domain
Post by rpw »
Been trying to search forum (no success) on how to add another smtp domain. i.e. we have a domain.org and a domain.com. I've only added the .org address during initial setup. How do I (can I) add the second domain. I'm starting to get emails building in the queue for the .com address.
Also how do I add another user to access mail watch? I'd like separate users for the additional users who will monitor Mailwatch.
Richard
darky83
Site Admin
Re: add domain
Post by darky83 »
rpw
Re: add domain
Post by rpw »
Don't know why but when I log in as root it just takes me to the prompt. How do I start the configuration from there?
darky83
Site Admin
Re: add domain
Post by darky83 »
Use your normal user account.
It is a bad practice to use the root user to logon to a system.
When you login with your normal user it will invoke EFA-Configure.
rpw
Re: add domain
Post by rpw »
It won't let me. Keeps saying bad password. I'm able to log into mailwatch with normal user ok.
rpw
Re: add domain
Post by rpw »
Fixed it (password). Now to configure. Problem was resolved by changing password for the user account. Turns out the "+" sign can't be used on Linux. Once I was able to find where to change it in Webmin and after fighting with Java I was able to change it to a more friendly password. After that it was easy to add the domains.
Again thanks. Richard.
