ClamAV stops working
Posted: 09 Jul 2014 10:24
I've similar situation twice,
clamd stop working.
Log:
So probably permissions:
Any idea to resolve issue?
clamd stop working.
Log:
Wed Jul 9 12:15:37 2014 -> HTML support enabled.
Wed Jul 9 12:15:37 2014 -> Self checking every 600 seconds.
Wed Jul 9 12:15:49 2014 -> /var/spool/MailScanner/incoming/30518/D7AB1100746.A2898.message: Suspect.DoubleExtension-zippwd-15 FOUND
**Wed Jul 9 12:15:52 2014 -> WARNING: lstat() failed on: /var/spool/MailScanner/incoming/30518/4A1A9100745.AF0A5/tnef_wAFQ8
**Wed Jul 9 12:15:52 2014 -> WARNING: lstat() failed on: /var/spool/MailScanner/incoming/30531/70613100748.ACC9E/tnef71AGfX
Wed Jul 9 12:15:52 2014 -> /var/spool/MailScanner/incoming/30518/D7AB1100746.A2898/n09-07-2014.9804887301.pdf.zip: Suspect.DoubleExtension-zippwd-15 FOUNDCode: Select all
ls -la /var/spool/MailScanner/incoming/30518/4A1A9100745.AF0A5
total 132
drwxr-xr-x 3 postfix clamav 140 Jul 9 12:15 .
drwxr-xr-x 32 postfix clamav 1840 Jul 9 12:15 ..
-rw-r--r-- 1 postfix clamav 8040 Jul 9 12:15 nmsg-30518-219.txt
-rw-r--r-- 1 postfix clamav 7672 Jul 9 12:15 nmsg-30518-220.txt
-rw-r--r-- 1 postfix clamav 6297 Jul 9 12:15 nmsg-30518-221.txt
-rw-r--r-- 1 postfix clamav 107826 Jul 9 12:15 nwinmail.dat
drwx------ 2 postfix **postfix** 60 Jul 9 12:15 tnef_wAFQ8
