Smarthost authentication
ward0g
Post by ward0g » 07 Jul 2014 19:54
Hello all
i just installed EFA to replace my scrollout appliance
Scrollout did the job as expected but i need more features
i'm stuck in configuration ... i'm not able to configure authentication against my IPS's SMTP relay
ISP relay requires SMTP traffic on port 587 with authentication
i managed to use submission but not to configure auth
i tried to add it in postfix config without success
relayhost = isp-relay.dom:587
smtp_sasl_auth_enable = yes
smtp_sasl_password_maps = hash:/etc/postfix/sasl_passwd
smtp_sasl_security_options = noanonymous
smtp_tls_security_level = may
smtpd_tls_auth_only = yes
i searched in the forum and google but didn't find anything regarding this
sorry for my english ;-)
thanks in advance
Re: Smarthost authentication
Post by shawniverson » 09 Jul 2014 01:33
Try
smtpd_sasl_auth_enable = yes
smtpd_sasl_security_options = noanonymous
ChrisMac715
Post by ChrisMac715 » 09 Jan 2015 08:26
I have the same problem. The authentification isn´t successful to the smarthost provider.
"Relay not permitted"
Can anybody help me?
e-d-i-t
Post by e-d-i-t » 24 Jan 2019 09:17
If anybody walks in here:
http://postfix.state-of-mind.de/patrick ... rvers.html
Don't forget to make a db out of the user/pass file on the prompt with: postmap hash:/etc/postfix/sasl_passwd
I still need to setup my EFA using SMTP Auth so I don't know if this is the actual fix.
Post by henk » 24 Jan 2019 14:37
Why do you need to mention the port 587?
/etc/postfix/main.cf
# In the case of SMTP, specify a domain, host, host:port, [host]:port,
# [address] or [address]:port; the form [host] turns off MX lookups.
relayhost = [smtp.isp-relay.dom]
/etc/postfix/relay_passwd
smtp.isp-relay.dom   <<provided isp_user>>:<<provided isp_PASSWORD>>
postmap /etc/postfix/sasl_passwd
Assuming your postfix config is correct :shifty: , give it a try
e-d-i-t
Post by e-d-i-t » 08 May 2019 12:47
Well, I am out of options right now. Trying to get authenticated smtp working on a smarthost.
Still I get: bounced (host smtp.xxxxx.nl[xx.xxx.xxx.xx] said: 554 5.7.1 Recipient address rejected: Authentication required (in reply to RCPT TO command))
If I try relaying with an external tester: www.smtper.net on port 587, then it works.
But I cannot get EFA4 to authenticate succesfully.
My current config in main.cf:
relayhost = smtp.xxxxx.nl:587
As I have installed EFA4 clean on a minimal CentOS7, is there anything I need to do concerning any certificate I need to create? Or is that out of the box allready installed? Cause this may be my last thing I can think of to check.
