Hi all,
I've been using E.F.A. for some time now and I still have some working ESVA setups running at a few sites.
If I recall correctly, a major security breach in the cgi that allowed to release messages marked as spam (I'm talking about ESVA) forced us to close all http/https connections from the exterior and allow them only from within the network (or via vpn). From a security point-of-view it's nice, but it's a huge pain in the @ss to the user side.
I was wondering if those issues have been solved in EFA or if allowing https from the outside is still a huge concern (I say huge because it's always a concern).
thanks in advance.
Tiago Marques
release-msg.cgi security
Re: release-msg.cgi security
That issue with the broken cgi in esva has been fixed, we use a token system and use input validation to make sure this won't happen again.
tmarquespt
ah great to know.
thanks for the great work with EFA.
TM
TM
Also, EFA supports Trusted Networks for additional security (off by default).
