RBL settings - combination use - blocking vs scoring
Posted: 02 Jun 2014 12:33
Hi since im pretty new user on this spam filter can someone break down the locations / config files - setup for RBL's?
I am aware of the entries in the Postifix Config - putting an RBL here will reject the msg and not be seen by mailwatch / mail scanner.. good example is zenhaus or Barracuda (highly trusted)
I am also aware that you can add / use RBL's in MailScanner? Where is this done and how do we get to the file to edit it.?
IS this a scoring that is applied to the email and will a HIT here also show as "Listed in RBL" in mail watch?
What is the method to add / use RBL's in Mailscanner and how do we get to it? I'm assuming it's a config file as it is not in the console menu.
I am also aware we can add RBL's to Spam Assassin. What do we need to do to put the RBL's here?
This method is most likely a scoring method if there is a HIT on an RBL used in SpamAssassin?
I really really like this EFA mail filter setup but would like to tweak it using a few different methods with RBL's as some would be great to add for scoring to increase the score of the spam and others can be used for out right blocking. I have been using a combination of RBL's over the years and have a pretty good idea where I'd like to use them scoring vs blocking.
I have been running this filter for a month now and believe it or no it works really well. I have seen a few pieces of email get through and that is why I would like access to make a few changes using rbl scoring. NICE JOB!
