multiples AD domain access
Posted: 29 May 2014 16:48
by david
Hi All,
is it possible configure EFA to allow users from different AD domain? i mean, i have 3 AD domain ( abc.es , def.net , xyz.com ) in 3 different server. Is it possible allow login in EFA from all my AD server simultaneously?
thanks a lot for any support or ideas
David
Re: multiples AD domain access
Posted: 06 Aug 2014 11:51
by david
does anyone know if this is it possible?
thanks
Posted: 08 Aug 2014 00:15
I believe this may take some modification in the MailWatch code to accomplish. Right now it only supports a single domain
Posted: 08 Aug 2014 11:32
by david
shawniverson wrote:I believe this may take some modification in the MailWatch code to accomplish. Right now it only supports a single domain
thanks shawniverson. Much apreciate your support
if i will find a workaround i'll let you know
Posted: 19 Aug 2014 23:50
by mcit
Hi David
I have been looking at doing a similar thing, except I also have non AD servers that my EFA filters spam for.
You can try the suggestion that was given to me in this thread:
/viewtopic.php?f=14&t=716
It seems to indicate you can connect to multiple AD servers for address verification.
Matthew
