EFA + Fail2Ban
Posted: 24 May 2014 21:00
by javier.mireles
I do not speak English correctly, an apology ...
Someone who has configured EFA + fail2ban to protect the failed logon attempts on port 443 and port 80 and also share the settings used.
Thank you in advanced
Re: EFA + Fail2Ban
Posted: 28 May 2014 01:35
I have not, but it sounds like something we could use as part of the project.
I think I'll give it a shot.
Re: EFA + Fail2Ban
Posted: 04 Jun 2014 20:44
by javier.mireles
Re: EFA + Fail2Ban
Posted: 07 Jun 2014 23:44
Tomorrow...
Re: EFA + Fail2Ban
Posted: 26 Mar 2015 08:57
Yeah, this would be a good feature.
Re: EFA + Fail2Ban
Posted: 26 Mar 2015 16:59
Re: EFA + Fail2Ban
Posted: 19 Jul 2016 08:12
Are you planning to integrate this into EFA somehow or only add it to the appliance?
If not should I go ahead for now and manually configure and setup fail2ban? I've done that a couple of times I'm just wondering if its worth waiting for your implementation.
