				Pyzor bug I think
				Posted: 12 May 2014 02:43
				by Michaelv
				I seem to be getting random pyzor crashes.
May 12 00:56:42 relay abrt: detected unhandled Python exception in '/usr/bin/pyzor'
May 12 00:56:42 relay abrt: can't communicate with ABRT daemon, is it running? [Errno 2] No such file or directory
pyzor ping
public.pyzor.org:24441  (200, 'OK')
I've just turned on abrt to log the error.
Most of the time, I see pyzor listed in the spam checks. So it is working most of the time.
Anybody else seen this?
Regards,
Michael
				Re: Pyzor bug I think
				Posted: 12 May 2014 23:12
				I wonder if the Pyzor cache is the problem?
Thanks to Michaelv for this tip!
				Posted: 13 May 2014 00:21
				by Michaelv
				Hi Shawn,
No that is for DCC if it always complaint's it cannot find server.
Then you use "sudo cdcc rtt" that will will drop its cache and re-probe all the servers it can reach.
Not sure what changing abrtd conf to support an pyzor which is not in a package.
Wait a bit, I'll post the results of the next crash.
Regards,
Michael
				Posted: 13 May 2014 13:03
				Posted: 14 May 2014 02:14
				by Michaelv
				Hi all,
Okay got more details on this problem.
Somehow it creates the problem when the emails logs are
May 14 02:52:55 relay postfix/cleanup[12563]: F1D3910041E: hold: header Received: by <myserver.hostname> (Postfix, from userid 0)??id F1D3910041E;
 Wed, 14 May 2014 02:52:54 +0800 (SGT) from local; from=<user@"hostdomainname"> to=<root@localhost."hostdomainname">
May 14 02:52:55 relay postfix/cleanup[12563]: F1D3910041E: message-id=<53726a06.9/nu/QotLWTgmyCw%user@localhost>
May 14 02:52:59 relay MailScanner[6593]: New Batch: Scanning 1 messages, 1957 bytes
May 14 02:52:59 relay MailScanner[6593]: Virus and Content Scanning: Starting
May 14 02:52:59 relay MailScanner[6593]: Spam Checks: Starting
May 14 02:52:59 relay MailScanner[6593]: Expired 1 records from the SpamAssassin cache
May 14 02:52:59 relay MailScanner[6593]: Whitelist refresh time reached
May 14 02:52:59 relay MailScanner[6593]: Starting up SQL Whitelist
May 14 02:52:59 relay MailScanner[6593]: Read 1 whitelist entries
May 14 02:52:59 relay MailScanner[6593]: Message F1D3910041E.A2556 from 127.0.0.1 (user@"hostdomainname") is whitelisted
May 14 02:52:59 relay MailScanner[6593]: Requeue: F1D3910041E.A2556 to D80AC100885
May 14 02:52:59 relay MailScanner[6593]: Uninfected: Delivered 1 messages
May 14 02:52:59 relay postfix/qmgr[23343]: D80AC100885: from=<
user@antlabs.com>, size=1736, nrcpt=1 (queue active)
May 14 02:52:59 relay MailScanner[6593]: Deleted 1 messages from processing-database
May 14 02:52:59 relay MailScanner[6593]: Started SQL Logging child
May 14 02:52:59 relay postfix/cleanup[12563]: 9D1A3100893: message-id=<53726a06.9/nu/QotLWTgmyCw%user@localhost>
May 14 02:52:59 relay postfix/qmgr[23343]: 9D1A3100893: from=<user@"hostdomainname">, size=2218, nrcpt=1 (queue active)
May 14 02:52:59 relay postfix/local[12721]: D80AC100885: to=<root@localhost."hostdomainname">, orig_to=<root@localhost>, relay=local, delay=4.7, delays=4.5/0.15/0/0.01, dsn=2.0.0, status=sent (forwarded as 9D1A3100893)
May 14 02:52:59 relay postfix/qmgr[23343]: D80AC100885: removed
May 14 02:53:00 relay postfix/smtp[12724]: 9D1A3100893: to=<michael.van@"domainname">, orig_to=<root@localhost>, relay=x.x.x.x[x.x.x.x]:25, delay=0.56, delays=0.01/0.02/0.14/0.39, dsn=2.6.0, status=sent (250 2.6.0 <53726a06.9/nu/QotLWTgmyCw%user@localhost> Queued mail for delivery)
(of course I've replaced my domain name with "domainname" and so on.
so its internally generated email. Not sure from whom yet, or maybe its the error that is logged in abrt.
Now that email is
abrt_version:   2.0.8
cmdline:        /usr/bin/python -Wignore::DeprecationWarning /usr/bin/pyzor report
executable:     /usr/bin/pyzor
kernel:         2.6.32-431.3.1.el6.x86_64
last_occurrence: 1400007163
time:           Wed 14 May 2014 02:52:43 AM SGT
uid:            48
username:       apache
sosreport.tar.xz: Binary file, 1712100 bytes
backtrace:
:client.py:180:run:OSError: [Errno 13] Permission denied: '/var/www/.pyzor'
:Traceback (most recent call last):
:  File "/usr/bin/pyzor", line 8, in <module>
:    pyzor.client.run()
:  File "/usr/lib/python2.6/site-packages/pyzor/client.py", line 1022, in run
:    ExecCall().run()
:  File "/usr/lib/python2.6/site-packages/pyzor/client.py", line 180, in run
:    os.mkdir(homedir)
:Local variables in innermost frame:
:homedir: '/var/www/.pyzor'
:k: 'Timeout'
:args: ['report']
ptions: []
:self: <pyzor.client.ExecCall object at 0x7ff2e3416200>
:debug: 0
:defaults: {'DiscoverServersURL': '
http://pyzor.sourceforge.net/cgi-bin/in ... vers-0-3-x', 'ServersFile': 'servers', 'AccountsFile': 'accounts', 'Timeout': '5'}
 '5'
:specified_homedir: None
:config: <pyzor.Config object at 0x7ff2e27b8a10>
:servers_fn: '/var/www/.pyzor/servers'
:log: None
So it cannot find pyzor servers in the directory /var/spool/postfix/.pyzor
Not sure why it needs to.
I've used the same fix for the razor mail bug component.
sudo ln -s /var/spool/postfix/.pyzor /var/www/.pyzor
sudo chown -R postfix:apache /var/spool/postfix/.pyzor
sudo chmod ug+rwx /var/spool/postfix/.pyzor
sudo chmod ug+rw /var/spool/postfix/.pyzor/*
Will report back in a few days to see if the problem reoccurs.
Regards,
Michael
				Posted: 15 May 2014 21:49
				Thanks Michael!
I'll post an issue to Github after you confirm the issue is gone.
				Posted: 19 May 2014 02:07
				by Michaelv
				Hi Shawn,
Looks like the bug is gone.
Haven't see it pop up for the last 5 days.
The bug used to pop up about 4-10 times a day.
Regards,
Michael
				Posted: 21 May 2014 01:19
				Posted: 29 Jun 2014 20:03
				by darky83
				Added the fix to the 3.0.0.5 release
				Posted: 25 Jan 2017 15:41
				Not sure this is the same problem but I am seeing this in my logs quite often:
Jan 25 16:31:27 jacob abrt: detected unhandled Python exception in '/usr/bin/pyzor'
Jan 25 16:31:27 jacob abrt: can't communicate with ABRT daemon, is it running? [Errno 2] No such file or directory
				Posted: 20 Mar 2017 08:21
				Yes, I know there are 3 years between the date the bug was fixed and me getting this error but can someone confirm whether anyone else is experiencing this?
				Posted: 20 Mar 2017 08:55
				by Woger
				I don't get  the error, but my installation is only 1 day old
What version are you on? and did you check the above settings?
My settings are like these:
/var/spool/postfix:
drwxrwxr-x.  2 postfix apache   4096 Feb 19 15:57 .pyzor
/var/www/.pyzor/:
lrwxrwxrwx.  1 root    root      25 Feb 19 15:57 .pyzor -> /var/spool/postfix/.pyzor
The directory is empty
Greetings,
Roger
				Posted: 21 Mar 2017 00:46
				ovizii wrote: 20 Mar 2017 08:21
I wonder if something is up with pyzor itself in your install?  Perhaps a reinstall of pyzor is in order?
				Posted: 29 Mar 2017 08:52
				I'll try that next weekend as I will be also upgrading to 3.0.1.9
				Posted: 25 Apr 2017 08:49
				still didn't get around to upgrade from 3.0.1.5 as I saw loads of issues with upgrading on this forum. Will watch 3.0.2.1 for another week before taking the plunge.
Did a yum reinstall pyzor and will see if that helped.
