Dear Team,
I am still using ESVA ,,, so can you help me ,,, our client are receiving email attachemnt exe inside zip attachment, though I have blocked in
cat /etc/MailScanner/archives.filename.rules.conf
cat/etc/MailScanner/archives.filetype.rules.conf
Any other settings...
Thanks in advance
UdayRana
block exe inside zip attachment
Re: block exe inside zip attachment
In /etc/MailScanner/MailScanner.conf, the default value of Max. Archive Depth is 0
I've changed it to 2 for me. Works perfect. Even renamed and zipped files will be discovered and blocked.
Maximum Archive Depth = 0
Maximum Archive Depth = 2
