/etc/init.d/vmtoolsd 0 bytes long
Posted: 04 May 2014 19:11
Just noticed....some of you that may be using open-vm-tools...
Make sure you have a real vmtoolsd init script (and that it is not 0 bytes in size)
wget -O /etc/init.d/vmtoolsd https://raw.githubusercontent.com/E-F-A/v3/3.0.0.4/build/EFA/vmtoolsd.init --no-check-certificate
