I just noticed this.. I was setting up a staging vm for my testing.
Patch 4 has this error..
Error: Package: clamd-0.98.1-1.el6.rf.x86_64 (rpmforge)
Requires: clamav = 0.98.1-1.el6.rf
Installed: clamav-0.98-2.el6.rf.x86_64 (@rpmforge)
clamav = 0.98-2.el6.rf
Somehow it won't update it. It was still running 0.98 manually updating clamd clamav, works properly to 0.98-1
Not sure what is 0.98-2
I think you have two lines for this update.
---> Package clamd.x86_64 0:0.98-2.el6.rf will be updated
---> Package clamd.x86_64 0:0.98.1-1.el6.rf will be an update
--> Processing Dependency: clamav = 0.98.1-1.el6.rf for package: clamd-0.98.1-1.el6.rf.x86_64
Clamav website says stable version is 0.98-1 and no release candidate for next version.
Regards,
Michael
Bug in patch 4
