Guys,
I downloaded this 2-3 days ago, after upgrade to 3.0.0.4 The EFA user and menu is not visible. Is there a separate command to launch the menu?
I installed this a couple times and same process happens after upgrade.
How do we get to the configuration menu at the console?
I am going to do this again (download and install the version available 3.0.0.1 and then update it again from scratch to 3.0.0.4) TODAY 4-27-13.
If I am missing something please let me know.
EFA Configure
Re: EFA Configure
Hi there,
Sorry, i don't have a clue about your issue but i do have a small advice.
Install EFA as a virtual machine. after finishing first setup and before update, create a snapshot.
This way if anything goes wrong U can always go back and save time and effort.
Hope this helps.
Hope this helps.
Re: EFA Configure
I am running as a VM.
This is the steps
1) Download VM from website - this version is 3.0.0.1
2) run through setup, at the end you get the efa configure menu
if I log out, and log back in, I get the EFA configure menu
3) perform update to 3.0.0.4
by running script sudo /usr/local/sbin/EFA-Update -update
4) when I log back in I get SHELL no EFA MENU
Is that clear enough?
EFA Configure Menu is NOT running when you log in after upgrade.
I also left it at 3.0.0.1 and waited overnight, it upgraded to 3.0.0.4
When I log in, I do not get the EFA configure menu, I get the shell
This is the steps
