Mailwatch Web UI Fails after restart
dbarsky88
Post by dbarsky88 »
Hi guys,
First off, thank you so much for making this appliance! It is excellent and it a pleasure to deploy and run.... works great with my Exchange 2013 instance!
I noticed that after a reboot my Mailwatch UI no longer works. When I navigate to http://EFAipAddress/ it redirects to http://EFAipAddress/mailscanner, asks me to log in but when I log in I get the following error:
Could not connect to database: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (111)
Likewise, I attempted to issue a reboot to see if it would fix the issue and I see the following mysql startup error as well:
Another MySQL daemon already running with the same exact unix socket
and directly after that
Starting mysqld: [FAILED]
right before this shows up it starts the Clam AntiVirus Daemon.
Any ideas?
Any help would be greatly appreciated :)
Re: Mailwatch Web UI Fails after restart
EFA-Configure has a "Mysql Recovery" option for this purpose :D
