Please verify read permissions on /var/spool/postfix/hold and /var/spool/postfix/incoming
Any thoughts?
Postfix - Hold and incoming
Re: Postfix - Hold and incoming
Could u please explain the issue more verbosely plz ?
My apologies. Please see the attached screen capture.
The message is displayed under the status header
- Untitled copy.jpg (30.93 KiB) Viewed 8166 times
sudo chown postfix:apache /var/spool/postfix/incoming
sudo chown postfix:apache /var/spool/postfix/hold
sudo chmod 740 /var/spool/postfix/incoming
sudo chmod 740 /var/spool/postfix/hold
