EFA webgui (MailWatch) change to HTTPS
Posted: 12 Apr 2014 18:16
I've installed the EFA 3.0.0.1 VM image, updated all available packages & upgraded to EFA 3.0.0.4 & rebooted.
So far all seems okay, except when I want to activate HTTPS (& reroute port 80 to 443 as well).
I go into EFA configuration (SSH) via option 11 (Apache settings) and activate HTTPS.
After that it's adios webinterface for MailWatch, neither HTTP nor HTTPS respond anymore. (IP, hostname, etc).
Only webmin is still responsive (https://ipaddress:10000)
Whatever I then try to change back via SSH or do a reboot, MailWatch webgui stays unavailable.
I tried several times by restoring a VM snapshot, try a slightly different approach, but same result each time
Not sure if this is a bug or some config issue at my end, any suggestions would be great
Paul.
Paul.
