testing v5 and missing the display of SPAM messages
ManFarang
Post by ManFarang »
installed v5 in a VM to test the functionality. Works...
and seems to look at mails :-)
good mails come in and are forwarded to the correct mailserver. These mails are displayed in "recent messages" page.
But in contrary to v4 that I used before NOT ONE spam message is displayed. And I'm sure spam mails are coming in...
V4 displayed spams, used different colours and had the ability to look at these spam mails and work on them.
So, what/where to change in the configuration to make that webpage behave like v4?
Thx for your help.
man
_M_P
Re: testing v5 and missing the display of SPAM messages
Post by _M_P »
have you tried
viewtopic.php?t=3393 ?
Best regards
ManFarang
Post by ManFarang »
no, not yes
Thx for the hint, will give it a try
best, man
ManFarang
Post by ManFarang »
thx, that helped in one way...
now the SPAMs appear in the list... but:
they appear twice (see attachment):
one normal
one with "{Spam?} in the subject and a score of zero
any ideas?
ManFarang
Post by ManFarang »
ManFarang wrote: 03 Aug 2025 10:30 thx, that helped in one way...
one normal
any ideas?
found it :-)
MailScanner.conf:
Spam Actions = store forward
should be:
