Here is the portion of the page where it is cutoff.
<td colspan="5">
<ul id="menu" class="yellow">
<li><a href="[status.php](view-source:https://domain.com/mailscanner/status.php)">Recent Messages</a></li>
<li><a href="[lists.php](view-source:https://domain.com/mailscanner/lists.php)">Block and Allow Lists</a></li>
<li><a href="[quarantine.php](view-source:https://domain.com/mailscanner/quarantine.php)">Quarantine</a></li>
<li><a href="[reports.php](view-source:https://domain.com/mailscanner/reports.php)">Search and Reports</a></li>
<li><a href="[other.php](view-source:https://domain.com/mailscanner/other.php)">Tools and Links</a></li>
<li><a href="[sf_version.php](view-source:https://domain.com/mailscanner/sf_version.php)">Software Versions</a></li>
<li><a href="[grey.php](view-source:https://domain.com/mailscanner/grey.php)">greylist</a></li>
<li><a href="[logout.php](view-source:https://domain.com/mailscanner/logout.php)">Logout</a></li>
<script>function changeLang() { document.cookie = "MW_LANG="+document.getElementById("langSelect").selectedOptions[0].value; location.reload();} </script><li class="lang"><select id="langSelect" class="lang" onChange="changeLang()">
<option value="de">Deutsch</option>
<option value="en" selected>English</option>
<option value="es-419">Español</option>
<option value="fr">Français</option>
<option value="it">Italiano</option>
<option value="ja">日本語</option>
<option value="nl">Nederlands</option>
<option value="pt_br">Português</option>
</select></li>
</ul>
</td>
</tr>
<tr>
<td colspan="5">Code: Select all
<td colspan="5">This is preventing me from being able to create and edit MailScanner blacklists. All other areas of the GUI seem to be loading correctly, and the overall functionality of this eFa instance appears to be at 100%.
See also https://github.com/E-F-A/eFa5/issues/29
